Convert RFA to DWG or DXF
8 ANTWORTEN 8
Nachricht 1 von 9
7372 Aufrufe, 8 Antworten
I need one small Revit symbol files converted to dwg or dxf so I can use them in a Autocad Architecture 2010 drawing.
Is this the correct place for help or should I post somewhere else?
8 ANTWORTEN 8
Nachricht 2 von 9
Sahay_R
als Antwort auf: Anonymous
You're in the right place all right!
In Revit -
1) Click on the R (if you are in 2018, click on File)>>Export>>DWG (or DXF - easier to use over different releases)
2) Follow the prompts
In AutoCAD - Insert as a block.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 3 von 9
kadmonkee
try this
it might need some cleanup in AutoCAD
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Nachricht 4 von 9
thamizhz
als Antwort auf: kadmonkee
Need to cleanup dwg 3d modelling files - like 2d symbol ?
Nachricht 5 von 9
Hi!
I have the same problem with this file. I need it in dxf or dwg.
Anyone can help me?
Thanks!
Nachricht 6 von 9
Did you try the suggestion above yet?
Nachricht 7 von 9
Hi!
I do not have Revit. I'm only using AutoCAD and I'm not able to insert a .rfa object in AutoCAD...
The file is this one: https://drive.google.com/open?id=1bd44dB_UybCN59TKCVmmY9ANUhsaHSZ1
Nachricht 8 von 9
kadmonkee
post 3 of 7 provided an AutoCAD 3d DWG.
yes some clean will always be needed
thank you
Nachricht 9 von 9
s.borello
Look at the Big R... you can export Revit to CAD formats.
