Hi friends,
I have some families which I want them to sit on top of the floor (not floating in the air) they are not hosted and I need to convert them to the face of the floor base. Please let me know if you have any ideas. Thanks
Check Work Plane-Based and uncheck Always Vertical in the Family. That work for you?
….alternatively, you could nest it into a Host-Based Family.
If the family was not made with a specific hosting default, there level based. Level based families typically have a default elevation parameter. Edit the family to be at the default elevation you want and they wont be floating.
as @barthbradley suggests, checking the Work Plane Based check box will allow you to pick the hosting option in the ribbon.
Howard Munsell
Another options is to nest the non-hosted family inside a hosted template, and patch through some/all of the required parameters. Or alternatively remodel the family in another template. Nesting if it is only for this particular project. Remodeling when you plan to use them in different projects.
Louis
Please mention Revit version, especially when uploading Revit files.
