Hi everyone!
I'm doing a massing to calculate floor areas, but it too complicated when using join geometry or cutting void from a big solid form (it causes so many errors).. then I tried to do it by a closed mesh geometry, which cant be used to compute mass floor (attached file).
Is there any way to convert mesh object to solid in massing? Please advice!
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Mass Floors can't be use with Meshes , only with Masses...
Anyway you can create almost any Mass Element without complicated boolean as you suggest....
You can do it by using Reference Points to create these Masses ...something as shown in my screencast:
3d modeling | Revit Products 2021 | Autodesk Knowledge Network
Constantin Stroescu
