I have a reporting length parameter and I want it to influence angle (the longer - the bigger angle you have)
Is it possible to make relationship between length and angle? (the problem is an error "Inconsistent units")
Gelöst! Gehe zur Lösung
Gelöst von Alfredo_Medina. Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous Hi
It should be possible
Here's an example. The units for Length are meters. The units for Angle is decimal degree. Therefore, in the forumla, you need to need to eliminate first the length unit (in this example, meters), by dividing the value of Length by 1 meter. Then, you multiply for a value in the desired units (degrees). In this case, I made Angle be two times the value of Length.
