Convert 3D dwg file to Revit corresponding structural objects
I have 3D file where each object is defined as polymesh in the file, I want to create corresponding structural or architectural objects in Revit, importing the whole model definitely works but Revit imports them as block model where I'm not being able to split for each element where I can modify.
Please see the attached file, each obect can be represented as I, C, U or any other common structural shape, what I know for sure which can help to convert those objects is, each object has the beginning and coordinates to modify, even the surface can be extracted from that in dwg file.
So my question is, what is the technique( dynamo script , REvit intrinsic feature) to convert those objects into Revit obejcts
