Hello.
I am taking a shot on this question. It is probably a no answer
I was asked to add grid lines and head to the site plan model. The issue is the grid head is too big. I created a smaller grid head size in the building model. 2 different grid head sizes.
Is there a way to change the grid head size in the site plan model?
Thank in advance
I run into the same issue. The one trick I use is create duplicate grid and save it as another Revit file. Modify the grid on that file to make it smaller. Then link it in and turn off the project grid and make the Revit link smaller grid show up on site plan.
Model the Bubble as a shared Generic Annotation (various types for different scale/size) and set each size/type to a subcategory. Nest that into the Grid Head - In the project you switch ON/OFF the subcategory relevant to the view scale
The Grid Name/Number would always be constant - by convention its Height should be 2.5 ... 2 works though for all scales
