Is it possible to control a material from within a schedule. It works of course with a loadable family with a shared material parameter but I want to do the same with a system family (roofs, walls etc.)
Families with TYPE or INSTANT parameter for the Material...
you can Map that Material to " Global Parameters " in the project...
( shared parameter and shared parameter files not required )
For ex..
Multiple furniture with two to three material parameters..
once loaded in the project, map those parameter to " PROJECTS GLOBAL PARAMETER "
Here, you need to create New parameters in Global Parameters..
Parameter A - in Global Parameter ( Material )
Parameter B - in Global Parameter ( Material )
Parameter C - in Global Parameter ( Material )
So any material parameter ( Instance or Type ) from families, can be mapped ..
so changing one global parameter can update multiple families ..
Global parameter
Ganesh, thanks for your answer but this is no answer to my question. I want to control wall, roof (system family)materials from within a schedule.
