Contour Maps - Color Coded by Elevation
6 ANTWORTEN 6
Nachricht 1 von 7
msmithCBRBB
2440 Aufrufe, 6 Antworten
Does anyone know how to create a Contour Map that displays the different elevations as different colors. I dont want the contour lines to change color, I want the fill between the contour lines to show up as a shaded color, similar to a heat map. Below is an example of what I would like to create in Revit. Is this even possible? Or do you have any other ideas of which program would work best to create such a contour map of the roofs on a home?
Beschriftungen (1)
6 ANTWORTEN 6
Nachricht 2 von 7
als Antwort auf: msmithCBRBB
You can use view filters to change the color of the element based on their elevation or height parameter.
Nachricht 3 von 7
alan_eu
As @ToanDN said, using filter is the full Revit way to do this
Otherwise, there's a free plugin you should love for many tasks
https://apps.autodesk.com/RVT/pt/Detail/Index?id=5056644120649615847&appLang=en&os=Win64
Try it and come back here to show us your results, please :leicht_lächelndes_Gesicht:
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou :leicht_lächelndes_Gesicht:
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! :leicht_lächelndes_Gesicht:
Nachricht 4 von 7
I would Photoshop it.
Out of curiosity, is this a stilt house?
Nachricht 5 von 7
syman2000
You can try create roof with 1000mm section and stack it on top of one another. Set the roof on plan as transparent. Change your color as consistent. Result is you will get contour intersecting it will display different color.
Nachricht 6 von 7
als Antwort auf: syman2000
I like it, @syman2000.  Old school.
Kudos.  :zwinkerndes_Gesicht:
Nachricht 7 von 7
paul_levrat32TU4
als Antwort auf: ToanDN
Hi !
Do you know if it's still possible to use the filter to do that ? I dont know how, and my attempt with "elevation at top" filter failed... I would be glad if someone can help me !!
Paul
