Contour lines in Toposolid Cuts.
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
Aben22
165 Aufrufe, 2 Antworten
Is there any way to display contour lines in areas that been cut from a toposolid using void forms?
The image below shows the white areas where I'd like the contour lines to show.
2 ANTWORTEN 2
Nachricht 2 von 3
vitorbortoncello
als Antwort auf: Aben22
no, you need to use sub divide and manipulate the elevation points
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 3
Aben22
Really impractical but pretty much what I had to do in the end, thank you for the confirmation.
