contour elevation
contour elevation
contour elevation
Hi! How could I elevate the contour line?  this file was imported from Acad. thanks.  I've attached the picture which my site looks like.
loboarch
Looks like the imported DWG file did not have contours that have a "Z" value. The DWG file needs to have 3d contour lines in order to create a toposurface that is not flat in Revit.
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-0536F8BE-FA0B-4CEE-A0A7-2C2D4171234D
Jeff Hanson
Principal Content Experience Designer
Revit Help |
I dont know how to make it in 3d since i am just a beginner on cad, and I just downloaded that file from here http://mbfoundation.org.ph/arts-design-architecture.html as you can see at the right side at the bottom downloads and the topographical survey. Are there anyways on how to make that 2d file cad into a 3d on revit? gosh, i need it badly.
cbcarch
You will need to make the lines into Polylines in cad, and give them a "Z" value by typing PEDIT then give a value for Z, such as 101, 102, etc.
Then save the dwg file and reload back into Revit.
Once inside Revit you can then select the dwg and create a Toposurface.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Hi, I dont understand when I type Pedit and then there's this precision that range from 0-99 and i dont get it. what was that for? and when I type just any num and there is this option that i would choose like close, join, width, and etc. I'm sorry, I am so lost. I just want to make the lines convert to polylines so I could have the Z values and import it on revit. Thanks
cbcarch
Sounds like you need to get a basic understanding of AutoCad first. Please post your Cad question on the AutoCad Forum.
Once you get it figured out in Cad, then re-post and if you need help in Revit I'd be glad to offer assistance.
Cliff B. Collins
Yah, I think so. Anyway, thanks for helping me out on this! much appreciated. 🙂
