How can I create continuous plaster in section view on Floor + Beam + Wall surfaces ?
I attached the print screen of what i achieved till now. But there is extra lines in the connection parts. ( shown in section.jpeg inside Red circles) How can we get rid of them?
Gelöst! Gehe zur Lösung
Gelöst von JasonKunkel. Gehe zur Lösung
If they are different categories, I don't believe Revit will "automatically" clean up those joints for you. I think your best bet is to:
Join Geometry should clean up those connections. It is, unfortunately, a manual process.
In addition to @JasonKunkel's suggestions, I can think of 2 more options:
1. Use the Modify -> Linework command (clicky). Select an "invisible" linetype, then grip edit the resulting line segments to create the intersection(s) you want.
2. Depending on the specific material you want, you could also use a "GWB" detail component or similar. This would give you the opportunity to show exactly how you want it assembled rather than just a relatively generic mass/model representation.
Thank you ! for the solution hints. 1st solution option is worked. I gave the same plaster material to the beam plaster and now i have all the way continuous plaster.
