Hi Friends,
Could u please help me out with this issue
I need the railing to be continuous like below image
I done but, i am unable to add the bottom rail with some offset,
i want to move the bottom rail to above red line instead of bottom
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Question:
If you send that rail to the workshop for fabrication would you tell them
Personally I would go with the 2nd and order 2 types of rail (same pattern / different heights)
If it is a matter of cosmetics and you find it crucial to have a continuous top rail.... you can hide or delete the top rail of either of them and extend the top rail of the 2nd by editing its path (tab to select top rail only) to cover both. But I find that unnecessary work
You may have an easier go of it by modeling your railing using Curtain Walls/Mullions/Empty System Panels. Just food for thought.
Also, don't forget the power of the panel - Baluster Panel that is. A Baluster Panel could be comprised of a number of 25mm square extrusions spaced 121.5mm apart. A Panel doesn't necessarily have to be a single extrusion representing a Glass Panel like the OOTB Panel.
Good luck.
Here is how I would approach this. File in 2022, I don't have 2020.
This one we can do but i am asking that is it possible to do continuous railing!
Yeah thanks, This one we can do but i am asking that is it possible to do continuous railing!
No you cannot...not with balusters.
An alternative to have it as 1 element is to model the balusters as a Panel and host on a wall which has a step...(you will have 4 corners to patch with a custom panel though.
@ToanDN I m gonna bestow on you the title Dr. of Repackaging lol ... @barthbradley idea of curtain wall is ingenious
