Content Libraries Revit 2016 missing
I have installed Revit Architecture 2016 on my computer (working with Windows 10), but after trying many times uninstalled - reinstalled with autodesk tool, there subsist the same problem : Generic Library is empty. The French library and the INTL Library are there, but not the generic.
I don't no how to do? Where can I find this library?
Thank you really much for your answers.
dzanta
The material library for autodesk software can be found here:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
dzanta
try this as well...
https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/AutoCAD-Customization...
Hello, thank you for your answer but the missing files are the family object, for exemple, there is no every walls, or I just have one choice ceiling, it's really limited. I work in French destop
I don't understand where is the library.
The most strange it's that when I open a exercice file made with an english version, there is all the library full, but nothing when I work on a french file. Where can I add the good library? Where is  it?
Thank a lot
dzanta
this sounds more like your software did not install properly.
do a clean uninstall via Start, Program, Autodesk, Autodesk Uninstall Tool
then reinstall software
