-Hola a todos, les dejo esta consulta. Estoy trabajando en un proyecto con dos alternativas de diseño, el cual a una planta le asigno un room y a la otra del mismo nivel, cuando quiero aplicarle un room para demostrar la diferencia respecto a la otra no me deja, ya que me previsualiza los room de la otra planta. Hay alguna forma de hacer lo que consulto?... Adjunto una imagen de lo que menciono.
-Hello everyone, I leave this query. I'm working on a project with two design alternatives, which to one floor I assign a room and the other the same level, when I want to apply a room to show the difference with respect to the other does not leave me, since I preview the rooms of the other plant. Is there any way to do what I consult? ... I attach an image of what I mention. Sorry my english, I use the google translator
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
You need to incorporate all the Room Boundaries into the same Option. One Option cannot reference another Option's Room Boundaries. So, you need to make a duplicate room to put in your secondary design option.
Hello, thanks for answering, I am trying the suggestion that you gave me, and it keeps throwing me the same error. Something must still have been wrongly configured for me to continue doing this.
Thanks for your help, reviewing I found the problem. Applying your suggestion, it works-
