Construction Template not showing Underlay
7 ANTWORTEN 7
Nachricht 1 von 8
658 Aufrufe, 7 Antworten
I have started a drawing in the Construction Template, when I go to Level 2, I can not get the underlay of my exsisting walls to show. I have tried my view range, and tried changing the cut plane. Anyone know what setting could fix this? Its so frustrating.
7 ANTWORTEN 7
Nachricht 2 von 8
Alan.johnson1970
als Antwort auf: Anonymous
Can you attach your project?
AJ.
Nachricht 3 von 8
check the Phase and the Phase Filter, and make sure both views have the same settings :leicht_lächelndes_Gesicht:
Nachricht 4 von 8
Viveka_CD
Hi @Anonymous
Check your view discipline. Views Inherit the Discipline of the Originating View. See if a view template may be defining the overrides.
Nachricht 5 von 8
"Underlay of existing walls"???  Do you mean the existing walls of the same Level or of a different Level.  Underlays are for showing elements from a different level or view direction on the main view, not for showing elements from a different Phase.
Nachricht 6 von 8
als Antwort auf: ToanDN
I need the underlay from Level 1 to appear on Level 2. When I am on Level 2 I can not see any underlay at all.
Nachricht 7 von 8
Alan.johnson1970
If you attach you project file we can look at to see what might be causing the issue.
AJ.
Nachricht 8 von 8
Viveka_CD
Hi @Anonymous
I just wanted to follow up here, any progress on this issue?
Do you seek more assistance from the community?
Please mark any posts that help with "Accept as Solution" and thanks! Kudos welcome.
