I have a simple panel family with height and width instance parameters, which is loaded in a window family. The window has two panels stacked on top of each other:
The bottom part's height can be adjusted, but whenever I adjust it, the top panel doesn't stay constrained:
Changing the width works without problems. I don't understand what am I doing wrong? I have attached the family so you can take a look (revit 2023).
Could you try by creating both panel and window in a single family data? I think the problem is because of this. Creating both in a single family, set desired parameters and doing some locking, I hope it helps you.
