Constrains Offset paramet
1 ANTWORT 1
Nachricht 1 von 2
jakob.kapun
331 Aufrufe, 1 Antwort
I prepared Hanging system family where is important to show in project height of installation/install elevation (when I will tag it will be visible height of istallation).
I prepared shared parameter Install elevation and inside family everything looks fine.
When I integrate family into project appears under constraints OFFSET with which I can also define height and
both height add up, but in tag is visible only height from install elevation.
How I can delet OFFSET from constraints if is not visible in family parameters?
How I can connect Offset with Install elevation so both height will be the same?
Thanks for help
1 ANTWORT 1
Nachricht 2 von 2
L.Maas
als Antwort auf: jakob.kapun
You can not. This offset parameter is automatically created by Revit when loading the family into a project.
You also can not tag this offset. So instruct your users to not use this offset and only use you own parameter.
Alternatively, you also could use the offset alone and then use spot elevation to  "tag" the height
Louis
Please mention Revit version, especially when uploading Revit files.
