What you need to do is:-
Create your radial array
Select the circular "path" for the array- NOT one of the array objects.
Click on the dimension icon to turn the temp dim for the radius (of the circular path) into a permanent dim.
You can then pich the permanent dim and change it to be a Label (ie a Parameter).
You now have parametric control over the array radius.
