Constrain with dimension
02:54 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying Revit to see if I can use it in my job.
I was trying out the family part option, and 1 ting annoyed me.
Is it possible to lock a part of the sketch with dimensions. As you can see in the picture below do I have this sketch. I would like to have it, so when i change the upper rectangle, the bottom stays with the 40300 mm from the edge, and with a size of 18000 mm. Also if I change the upper rectangle in both ways.
Is the possible or is it only possible to "constraint" when lines is touching each other?
