Hello everyone,
I am have an issue on the reference plans' constrians and I hope someone can help me.
In particular, I am working on a curtain wall panel and I wish to create dimentional parameters.
As you can see there are only two parameters (IntPanelW and IntPanelH) when I occured to this problem that the constrains can not be satisfied as soon as I change the parameters number. On the other hand I noticed that I can change their value by draging the plans and no warning pops out.
I have attached the rfa file if it can help to understand my problem.
Thank you anticipatedly.
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
Why fix the Height and Width? Why not let Revit make them automatically?
The width and height of curtain panels are controlled by the curtain wall grid spacing in the project. If you want to lock them, change the spacing to specific dimensions via Edit Curtain wall type.
You can fix them if you really want to. Don't Align and Lock to Template Ref. Planes. Draw new ones to Align and Lock to them - and pull your Labeled Dimensions between those RPs to control WxH parametrically.
you are right, I could let Revit to get H and W automatically. I am exploring a particular shape.
Thank you again!
