Constant Freezing
Constant Freezing
henry_eduvie4GZRT
Constant Freezing
henry_eduvie4GZRT
Hi All,
I am currently using Revit 2022 on my projects. Of lately, my software is freezing a lot (almost every 30mins) and most time i have to CTRl + ALT + DELETE to end the task and then restart the program. This is becoming really fustrating. Does anyone have any suggestion on how i can resolve this?
HVAC-Novice
@henry_eduvie4GZRT wrote:
Hi All,
Hardware? OS? All Windows and GPU updates? All R2022 updates?
Does any other power-hungry software show the same? How long ago did it start to error and how long before that did it work fine? What changed? Does it happen on other projects as well?
What add-ins and did you try to disable then to test?
Error reports/journal files sent to Autodesk?
You have to provide much more information for a complete stranger to be able to guess. but check all the above and make sure everything is updated.
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
SteveKStafford
What kind of network are these projects hosted on?
What anti-virus software system is in use?
Does your network system do any backing up of data during the work day?
Any 3rd party Revit tools in use?
Steve Stafford
