Conseptual Mass
1 ANTWORT 1
GELÖST
Nachricht 1 von 2
804 Aufrufe, 1 Antwort
Conseptual Mass
Hi guys
I have an issue in creating void sphere  using massing, that when I load it to any project it shows me this error:
*Mass contains no solid geometry. Mass Floors, volume, and surface area, won’t be computed.
what I should do make it work ?, also I am making the diameter as parameter so I can change it later using edit type.
Regards
1 ANTWORT 1
Nachricht 2 von 2
BIM.Consultant
als Antwort auf: Anonymous
The void in mass is meant to cut solid geometry within the same mass only! If you want your mass to cut solid elements in your project (such as columns, beams..), then you need to create ONLY solid geometry inside your mass, and click finish mass. Next, use join geometry tool between your mass and other elements. Now hide your mass, and you will see your cut done smoothly.
Masses are meant to remain hidden in your views. You shall use them to create mass floors, elements by face, curtain panels...etc then hide the masses and elements based on these masses will only be shown.
