connection to basement ceiling
4 REPLIES 4
379 Views, 4 Replies
i want to connect the outer walls with the ceiling. But i need a piece of insulation as shown at the picture I attached!
How can I draw this insulation at the edge of the ceiling? In 3d of corse 😉 ?
4 REPLIES 4
LisaDrago
That would be something you detail - not somehting you would show 3D. That would get into what I would consider over modeling.
You are not able to show the insulation in 3D, even if you locked the vire the insulation option is grayed out.
The only way I could think of showing it would 3D be to create a family.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
in reply to: LisaDrago
Hmm okay, but in reality you need e.g. less stones if there is an insulation!
Did nobody ever draw that bevore?
awes
Depending on need for schedules - model bricks and insulation both as walls or the then just insulation as a piece of floor around concrete floor. Height same as concrete floor. Easy to copy elements from level to level.
in reply to: awes
Ahh okay. But this is the "hard way" 😛
Isn't it possible with profiles or families?
Forma Design Contest
