Connecting Railing in different level of staircase and landing
2 ANTWORTEN 2
Nachricht 1 von 3
hninshwesin
113 Aufrufe, 2 Antworten
Hi all, I have a question. I am facing problem with railing in Revit architectural. I want to stop the railing in between each column and want to connect all the handrail smoothly. Another one is if I adjusted the bottom landing and staircase, I cannot get the same level as intermediate landing and Top Staircase. Please kindly advise.
Tags (1)
Beschriftungen (1)
2 ANTWORTEN 2
Nachricht 2 von 3
Sleepingfish_Kuo
als Antwort auf: hninshwesin
1. It's not easy to set railing to what you what. Maybe other one can solve it. In my case, I always use drafting view (2D lines) to explain how the railing actually is.
2. If the stair didn't change auto, try edit "Desired Number of Risers" to another value and then edit it back. Or check the rules of maximum riser height in type before that.
Nachricht 3 von 3
hninshwesin
I will try first. Thanks for your suggestion.
