If I sit a balcony on top of walls for instance, there will be a line dividing the wall from this balcony in 3d and elevation. How do I get rid of this line?
Gelöst! Gehe zur Lösung
Gelöst von Corsten.Au. Gehe zur Lösung
try this command " LW" Linework,
you can choose any line type, here you need " Invisible" and select any line and hide it..
Linework, controlling part of line to be invisible..
Is the balcony a wall? Does it share a common edge with the wall below? Same material? If so, they should join automatically. Perhaps using the Align Tool to align the faces will correct.
...FWIW: Typically, balcony walls follow the perimeter of a floor -- a.k.a. the balcony.
