When i insert the condulet family on a project and after i try to change the diameter value for 1", 1.1/2" etc., the family is deleted.
I' have done the .csv and inserted it in manage lookup tables' field.
I am sending both of files (.rfa and .csv) attached.
I am thinking that i am missing something, but i don't know what is (this is my frist MEP family).
Thanks for any help!
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
If you link your connectors, your issue may get sorted out. Select any of the connector and link the connector with another connector which is in inline with it. You have to do this process twice for 4 connectors.
Hope this may help.
I think I see the problem: some of the column headings have the wrong name in them; they don't correspond to any parameter name in the family. For instance, you show "DNI" in the table ("I" being a letter of the alphabet) , but I only see a "DN1" in the family ("1" being a number).
To tell you the truth no..but i've already solve this particular problem changing the units of electrical system (conduit fittings) on the project.
But i thank you for the willingness and i could accept your answer as a solution. If you want help me with other doubt i will thank you so much. I think now it is easier than the last one. Is about the same condulet family. When i am drawing the conduit from this inside a project they appear sloped, even thought i setted then with 0° angle inside the family parameter.
I've already posted this doubt on other post.
By the way, thanks a lot again.
@uoliveira: thanks for the credit. But, I was kind of curious what the real solution ended up being.
Regarding your other issue; where can I find that thread. I'll read it there and see if I can come up with something different from the other replies on that thread.
Take care.
The link with the other issue is below:
Unfortunately, no one has answered yet.
Thank you for any help.
