Hi, I can't join these walls and floor together. Why does it happen? The structure of both categories seems correct..
Join the balcony floor with the lower wall, join the lower wall with the upper wall. Switch join order if needed.
I can't get close to what you show by switching join order. I thinking something else is going on. Post the File.
You're using different materials. If this is what you're after, white layer material has to be the same one.
It's modeled wrong. Structural layers aren't going to be supported by Finish layers. The Floors need to physically contact the Structural core of the Walls. Right now, they don't.
