Concrete volume
13 ANTWORTEN 13
GELÖST
Nachricht 1 von 14
9343 Aufrufe, 13 Antworten
Concrete volume
is there a way to obtain entire concrete building volume (material takeoff)!?
Do I have to summon foundations, floors, columns etc. or is there a workaround?
Regards!
13 ANTWORTEN 13
Nachricht 2 von 14
als Antwort auf: Anonymous
Use a multi-category material take-off schedule.
Nachricht 3 von 14
als Antwort auf: ToanDN
@ToanDN
...tried to make a multi category takeoff schedule but something's wrong.
I should have around 550 m3 of concrete but Revit calculates "Grand total" 229m3.
What am I missing?
Thanks for your time!!!
Nachricht 4 von 14
Do you have multiple phases? What are the elements with the concrete material?
Nachricht 5 von 14
all materials are "cast in place concrete C25", and the elements are beams, columns, slabs and foundation slabs, stairs.
There are no phases.
Regards!
Nachricht 6 von 14
If you add the Category column to the schedule, do you see any categories are missing?  How did you come up with the 533 m3 figure?
Nachricht 7 von 14
I found where Revit doesn't properly summon volumes:
1. Floors (Grand total is 5m3)???
2. Structural Foundations
Grand total is 4m3???
So, after summoning I have around 550m3 as it should be.
Why is this happening? Is this a bug?
Regards!
Nachricht 8 von 14
4 and 5 are Count Totals, not Volume Totals.  You need to go to Format tab and set the Volume filed to Calculate Totals.
Nachricht 9 von 14
@ToanDN
ah...that's the problem,.....my mistake...
Thank you so much!
Regards!
Nachricht 10 von 14
How to do that so it shows volume?
Nachricht 11 von 14
RDAOU
Nachricht 12 von 14
als Antwort auf: RDAOU
@RDAOU Thank you!
Nachricht 13 von 14
Not sure that I know how to accept this as a solution: can't see this option
Nachricht 14 von 14
RDAOU
@Anonymous
You can only accept solutions on Posts which you start...Moreover, there is already a solution for this post :leicht_lächelndes_Gesicht: so all is good .
