Gelöst! Gehe zur Lösung
Gelöst von dzanta. Gehe zur Lösung
you can pull the volume of any material within any object in revit by creating a Material Takeoff Schedule. Go to the View Tab, then Create Panel, then Schedules, then Material Takeoff....choose the object category that has the concrete you need to pull out (i.e. floors, furniture, equipment, etc.). Create the MTO with the columns that start with Material: Volume, Material: Name, etc...Use Formatting and other tabs to get totals and appearance settings the way you want.
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
