Im having trouble with managing the dots that you use to change the form of an "edge" when in x-ray mode. For som of the dots, all three "coordinate-arrows"(I dont know the actual name) show as in the picture below.
And for some dots only two "coordinate arrows" shows. Does anyone know how why this is?
best regards,
Viktor
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
from my own observations I understood that :
As long as the New created Edge is hosted on a Face, you are not allowed to move the Point of intersection of the new Edge with a Profile on side direction within that Face ( that will not change the Face geometry). But, once you push the Point from that Face using Normal direction to the Face, then the Edge becomes a real edge between to different Faces and now you'll be able to move it all three directions.
Constantin Stroescu
