Conceptual Mass - can’t create roof by face - because it contains only mesh geom
2 ANTWORTEN 2
Nachricht 1 von 3
rita.aguiar
677 Aufrufe, 2 Antworten
I have created a script in dynamo, which results in a Surface (Surface.ByPerimeterPoints), that is generated as a conceptual mass in Revit.
I then loaded this new family into my revit project and now I wish to create a roof by face.
However, I get a warning: “Mass contains only mesh geometry, which can’t be used to compute Mass Floors, volume, or surface area.”
I have tried: importing the instance, I have also tried inserting a SAT in a inplace mass. I hoped that the spring node to import a family instance would work, but it did not.
How should I approach this?
Any help would be appretiated!
Conceptual MassConceptual MassDynamo ScriptDynamo ScriptRevit Project WarningRevit Project Warning
Tags (1)
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: rita.aguiar
It might be easier to generate a roof by boundary then use the Rhythm package to generate the additional points from the points provided in your Dynamo script.
Nachricht 3 von 3
Ignore the warning, it is for generating floors by slicing Levels through a Solid form.  Wall and Roof by face can be generated from surface-only forms just fine.
