Good morning, i am currently trying to model a pavillon vault in revit with conceptual mass. For some arches this would not work. Anyone had this issue? Adding and Edit. I switched to lines, and i have another weird results. Is there a way to control how it joins the lines?
arches joined correctly
Arches not joined
Lines joined randomly
Gelöst! Gehe zur Lösung
Gelöst von constantin.stroescu. Gehe zur Lösung
Great question, i had the same issue while dealing with irregular vaults on old buildings.
it depends how you do create the Mass...
you can see here an example that shows how I use to do it:
Constantin Stroescu
I will try that, see if it works with irregural bases. In the end, with lines arches and tweaking the geometry i managed to get my result
