I need to provide two informations in my schedule:
1) floor area
2) floor area, where room's height is above 1,9m ( I have a sloped roof)
I have managed to achieve those two informations in two schedules but not at the same time (I change computation height on level).
Is there a way to get to those two informations in one schedule at once?
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Hey,
thanks, works like charm.
how did you place both areas in two columns? those are two schedules combined, or is it possible to manage them in one schedule?
"area@level 1", "area@level 2"
I have to say, sounds like you two are communicating telepathically
heh, kind of.
But I still do not know how to present both areas in one table - one next to each other.
floor area | usage area
When I change computation height, then it affects floor area.
So... can you help me out, how it is made in ine the post above?
No need to change the computational Height... I would do the following
Watch GIF below and check out the attached 2020 Sample file
Yes!
thank you very much! I have managed to change it to my data, and managed to add some extra levels:-)
Thank you very much for a very detailed instructions and also for the file, that helped a lot!:-)
