Hello all,
How do you compose your walls in an architectural project?
Do you create a type of wall with multiple layers (concrete, insutation, epoxy resin) or separated walls?
Which is the best workflow in order to create correct materials schedules, calculating the surface of each material?
Thank you in advance for your ideas!
You create new wall types by duplicating an existing wall, and adding / removing layers.
Each layer has a function / material / thickness. You can also ad sweeps and reveals, split regions and assign layers.
Then you can do a 'material take off' schedule and get totals for area/volume of those material layers.
You can also create stacked walls out of multiple wall types.
We use both methods. We routinely combine multi-layered walls with single layered wall.
