Component not showing in View
4 ANTWORTEN 4
Nachricht 1 von 5
selahforneyXGEU8
582 Aufrufe, 4 Antworten
Hi, I have a component(wall sconce) that I had downloaded from BimObject in my project, however it is not visible from the floor plan? I did a section view and they are being placed on the wall, they jus aren't visible in floor plan view. I checked VG settings and everything checks out... any tips would be greatly appreciated!  :leicht_lächelndes_Gesicht:sconces not showing.jpgsconces on wall.jpg
Beschriftungen (1)
4 ANTWORTEN 4
Nachricht 2 von 5
ennujozlagam
als Antwort auf: selahforneyXGEU8
have you try to change your detail level to fine or coarse and check your phasing and see if helps. thanks
Nachricht 3 von 5
martijn_pater
Check the geometry's visibility settings in the family.
Nachricht 4 von 5
check your view range settings and set it higher than the height of the sconces
Nachricht 5 von 5
Mohamed-Nassar
Check View range and Phasing
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
