Component disappears after editing families
2 ANTWORTEN 2
Nachricht 1 von 3
957 Aufrufe, 2 Antworten
Hi everyone,
I've imported families from BIM Objects which have a box around it (I assume its not a scope box because it doesn't show any properties for it). When I try to delete the box (Edit families), the component disappears in 3d views.
My phases/views are right. Any ideas?
2 ANTWORTEN 2
Nachricht 2 von 3
als Antwort auf: Anonymous
I assume the box you deleted is for Coarse scale detail level. Change the view to Fine or change the more detailed geometry in the family to show for all detail levels.
Nachricht 3 von 3
What do you mean it doesn't show any properties? Your screenshot shows at you have a Generic Model selected. If you downloaded from BIMObject, I suspect it's displaying "correctly".  Want to post the family here?
http://help.autodesk.com/view/RVTLT/2016/ENU/?guid=GUID-749AEB1E-1B01-46BC-9790-3473BC769211
