I need to model exact stairs which is shown in picture.
Problem is that I have no idea how it is possible to make exact railing and bottom of the stairs.
I have Sketchup 3d model, maybe it is somehow possible to recreate them in revit using this model?
Gelöst! Gehe zur Lösung
Gelöst von martijn_pater. Gehe zur Lösung
You can try using the stair tool but it wont be a top notch quality stair...
You can import the Sketchup geometry and use it to model the stair in the massing environment? would that work for you?
I used shape bender in Sketchup for these stairs, unfortunately I can't find anything similar in Revit. And I cannot imagine other methods to make this shape...
I think you could best model it as adaptive component, or maybe import mass through other software (Rhino ie. / Archicad...)
