I want to model a complex flat roof with multiple slopes (1.png). The roof consists of a flat slab and the slope is to be achieved in the insulation layer - because of that I need to model it using the sub-elements menu - or at least I don't know of any other way. I tried to do it like in this video: https://youtu.be/vsfhgwbIXX0?t=497, but it's not working for me because of the higher complexity of my roof.
The problem is, I know the slopes, but not the heights of the edges - and I need the latter when using the sub-elements method. Because of that, my model turns out terribly triangulated (2.png), when it's supposed to be much simpler. Each of the green points would have a different height that I cannot specify.
My question is - is there a way to model a flat roof with a varying thickness insulation, by defining the slope and not the height of all the edges?
Thank you in advance for taking your time.
