Hej,
I was wondering is there a way to create this facade panel in Revit, without using other programs?
Any ideas? I tried using mass sweep, but it can't make the corner connections properly.
Thank you ![]()
Gelöst! Gehe zur Lösung
Gelöst von RDAOU. Gehe zur Lösung
@Anonymous
I would use a Pattern based generic Model
A Curtain wall with a custom panel can also get you there
The following youtube even has the exact same facade of the image you posted
