I have a project where the client is using Revit 2019.1 which is not available anymore. I upgraded to 2019.2 and can't see the files on BIM 360, but I can see them in a browser. I know Revit is not backwards compatible. However, are they compatible withing the year? Is 2019.1 compatible with 2019.2?
Within the year version of Revit, you should still be able to open and work with files. However, for the sake of stability, everyone who is working on these files should be on the same update/service pack.
2019.1 is still available, it has to be downloaded from manage.autodesk.com.
Click on the Suite info under All Products and Services then select Updates and Add-Ons when selected. Scroll down and it will be there.
