& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I seem to be having issues with producing accurate filled regions in my families. Filled regions with curved lines just don't seem to work. I can print most things at 144dpi and they look just fine. However, as soon as I introduce filled regions with curved lines using native Revit editing tools, I get very poor reproduction. Screen appearance in the Revit file is inaccurate because the curved lines are converted to segmented lines on screen (see attachment 01). In the pdfs it is worse because not only are the curved lines segmented lines, but they don't even meet at the end point with straight lines in the region (see attachment 02).
Is there any way to resolve this?
Create the logo in a vector graphics program and import it into Revit.
If you absolutely have to do this in Revit then try using raster printing in your print settings.
Thank you all for your replies.
So, is it the case that Revit can print AutoCAD fill patterns imported to annotation families using Vector graphics, but it can't print its own fill patterns without converting them to raster images first?
If so, then my workaround is to export the family from Revit to CAD, set up multiple files in CAD (one for each required visibility type) and then import them back into a generic annotation family in Revit. Then set up the visibility settings again in the family. What a right royal pain.
It seems that I spend a disproportionate amount of time explaining to people why Revit is actually a great program but you just have to find a "workaround".
@peter - this post has been edited due to Community Rules & Etiquette violation.
Update: disregard some of my previous comments.
On further examination, it seems that filled regions in a Revit Detail Item family print out as raster images. Also, if I import an AutoCAD dwg with hatched areas into a Detail Item family, it prints the hatching as a raster image, the same as for the native Revit detail.
Lines that are simple orthogonal ones or circles, for example, are printed off as vector images but it seems that other lines may be printed as raster images.
Strange, I've been working in Revit for a while now and I've never noticed this before. It's only that I have recently moved companies and the company logo is more complex than at my previous company.
I can't think of a workaround for this one, apart from beefing up the linework to cover up the rasterisation of the filled regions in the Revit solution (of this works).
Was anyone else aware of this? Am I missing something simple? (it wouldn't be the first time, and I'm not the Lone Ranger on this one, I'm sure).
P.S. This is a right bl00dy pain 😁 Anybody got any suggestions? Will I get Dion to add the issue to his blog page?
Some added screenshots: if I copy the logo to a legend, the logo looks better on screen (04.png compared to 05.png) but still plots off exactly the same (06.png). Just added this because I thought I had a possible workaround for a moment.
Why are you drafting a logo instead of putting it together where it should be designed Photoshop or Illustrator) then bringing it as an image or a pdf?!
Its a waste of time!!! tracing Fonts and logos in a CAD software...People stopped doing that even before Revit became a thing
Unfortunately, Revit exports dwgs with the images as separate files and this always looks unprofessional to me. Then it depends on a third party with unknown levels of skill to print them out correctly. This is why I prefer the logo as a native Revit detail.
Furthermore, images would still print in raster format so would not have clean lines. They can also create issues in themselves when you try to print them to pdf at higher resolutions in Revit (in case you aren't aware of this).
I could model it in 3D in Rhino or Revit if I wanted to and get clean lines. This gets a better end result than drawing it in Illustrator.
Instead of criticising users of the software when they just expect basic functionality, why don't you spend your time asking Autodesk to improve the basic functionality of their stuff. Is that too much to ask? Oh, you're an Autodesk sycophant and like to suck up to your master, is that it?
Good luck
On further examination, it seems that filled regions in a Revit Detail Item family print out as raster images. Also, if I import an AutoCAD dwg with hatched areas into a Detail Item family, it prints the hatching as a raster image, the same as for the native Revit detail.No. They print out as vector graphics unless you deliberately set Revit to print to raster. When you zoom in a raster, you see square pixels, not diagonal segments, evidently.
Again, No.
I can't think of a workaround for this one, apart from beefing up the linework to cover up the rasterisation of the filled regions in the Revit solution (of this works).Importing + not exploding CAD in a Revit family has already been suggested. Using PDF or image has also been suggested. Either works.
Everyone I've every met and every method I've researched for using graphics in Revit uses an inserted image for logos, its the fastest, cleanest and easiest method. If they still don't print clearly, then it's a problem at your end. Likely with graphics or printer drivers.
As for the other printing issues (filled region edges) that could be a symptom of the same issue.
I can totally relate to OP here. Don't be discouraged by other peoples mediocracy 🙂
I had three issues with the current revit solution:
My solution to the problem was to create a Hatch of the logo in autocad (only hatch, no lines), import it to a generic annotation family and then insert it to the sheet family. This solved all my problems.
TIP: when importing the dwg, import with a custom larger scale. Then scale back down afterwords. If i imported the logo with its real scale the results were not good, i.e. the voids in the letters were filled with colour and some small elements came without color.
Example: one of the letters in my logo from pdf print.
Hi Chaikampa,
Thank you for that suggestion.
I have used the method of scaling up an AutoCAD detail before inserting it, but I didn't think of using it for logos, so thank you for your idea.
It is encouraging that someone is willing to come up with a solution rather than to make uninformed and inflationary comments like some on here do. Well done.
I can now advise that I've tried Chaikampa's method (outlined previously) on a few projects and it works well.
Here is a blow up of part of a logo that I did for a Client (from the pdf).
This is much clearer that an imported image file.
In addition, it avoids the annoyance of having separate logos produced when exporting to AutoCAD (we have Clients who demand AutoCAD versions of files in addition to Revit and pdf's).
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
