Is it possible to create a combined schedule for the objects in the attached file?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
You cannot mix the Length of Specialty Equipment (shared parameter) with the Length of Railing (system parameter). I would just use only Railing for your egress path.
Rats. I had a feeling so. Thank you!
