Combining phases - rooms?
3 ANTWORTEN 3
Nachricht 1 von 4
koleary_ksa
261 Aufrufe, 3 Antworten
I have a multi-phase project that is complete and I am trying to clean it up to be an existing model for that building moving forward. If I start combining phases, what happens to the rooms? Do the rooms stay from both phases that are combined or do the rooms from a later phase stay while the earlier phase delete? Thanks!
3 ANTWORTEN 3
Nachricht 2 von 4
vitorbortoncello
als Antwort auf: koleary_ksa
The rooms don't combine or delete; they remain based on the phase you're working on
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
aAutodesk Certified Professional
Nachricht 3 von 4
Nachricht 4 von 4
HVAC-Novice
You can vote on these ideas to allow that:
https://forums.autodesk.com/t5/revit-ideas/add-rooms-and-spaces-into-phases-and-design-options/idi-p...
https://forums.autodesk.com/t5/revit-ideas/phasing-rooms/idi-p/8650858.
Not being able to change phases of a room or space is a serious lack in capability.
Revit version: R2025.4
