Hello everyone,
To create combined parameters for rooms and other elements we are using the "combine parameters" plugin by BIMODEL from the autodesk store. The plugin works well and it's easy to combine parameters together, but when changes are made to the parent parameter values, the combined one doesn't change. We are working with Revit 2021. Is there a way to solve it?
Tanks a lot!
It sounds like the Plugin should have an update function. The Plugin probably only gathers parameter values and adds them together, the task is not automated to sync whenever a value changes. Using Naviate, a plugin with similar functionality, the same problem occurs although you can always run the command again to update the values.
Ask directly to BIMODEL devs. It'll be hard to find someone else who uses that app and have the same isue.
