Columns won't attach to beams
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
mpukas
299 Aufrufe, 3 Antworten
I have this on-going problem when I copy columns and try to attach them to new columns. I get this warning:
The problem is the columns and beams are all completely unjoined, and the columns are detached. There's nothing more I can figure out to unjoin, detach, etc. What am I missing? TIA. mpp
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: mpukas
If you want fix it then delete the columns and place new ones.  If you want to know why then share the model.
Nachricht 3 von 4
mpukas
als Antwort auf: ToanDN
I found a hack work-around: select the column, in Properties, change the Column Style from Vertical to one of the Slanted options, de-select the column. Select the column again, and change the Column Style back to vertical, and it will then attach to the beam, as expected.
Yay Revit
Nachricht 4 von 4
aashford3Q2J4X
