Columns prevent perpendicular beams joining
1 ANTWORT 1
Nachricht 1 von 2
abhijeetraje
239 Aufrufe, 1 Antwort
Hi All
Please find attached screenshot of part of model. There are two columns, A and B . A is off the grid, B is exactly on the grid. The annotation column location mark shows same for both the columns. So does the schedule. This doesn't look correct. Ideally the distance of the central axis of column from the grid should be reflected in column location mark. Any solution to this?16-11-2018 1102.png16-11-2018 1103.png
1 ANTWORT 1
Nachricht 2 von 2
Luiscko
als Antwort auf: abhijeetraje
There is a common problem with this mark location when you copy one element a put nearby the original element, there is two ways first one is always create new elements or modified this wrong mark place with Dynamo.
Luis Rodríguez
BIM Structural | GEDCOM
GEDCOM Institute
YouTube |Facebook |Twitter | LinkedIn
