Columns prevent perpendicular beams joining
21 ANTWORTEN 21
GELÖST
Nachricht 1 von 22
vicktor1111111
3169 Aufrufe, 21 Antworten
Hi chaps, what's up, how are you doing. My problem is that when I join perpendicular beams as shown on the picture number 1 they remain unconnected because of the columns which support them on the corners. Strangely enough they become partly connected when I increase the gap between them and the column(picture number 2) and they become completely connected right after Revit says it cant keep column and the beam connected (picture number 3). This occurs when the gap reaches 1 1/2" (picture number 4).
Could you please tell me how can I solve this problem? Thank you very much for your help.
21 ANTWORTEN 21
Nachricht 2 von 22
als Antwort auf: vicktor1111111
Share your file.  We'll look at it.
Nachricht 3 von 22
Make your column's top offset be the depth of your beams.  You may have to pull back the beams some then trim them.
Usually I have my columns go floor to floor and the beams I 3D Connect top of column to top of column. Making them continuous from one side of the building to the other is not how it is built.
Also, pay attention to your analytical nodes...that will show how the structure is trying to connect to each other.
Nachricht 4 von 22
vicktor1111111
als Antwort auf: barthbradley
Unfortunately I can't attach the file I'm working in, cause the patron would object against the project of his building being divulged but I'll copy the problematic detail to a new file and post it. Thanks for advise.
Nachricht 5 von 22
Just save out the portion with the column and beam and send that one. We don't need proprietary content.
Nachricht 6 von 22
Select the column, right click the top blue round grip and disallow join, then miter the beams. But the proper way to build them are extend the column full height and stop the beams at the edges of the column.
Nachricht 7 von 22
Nachricht 8 von 22
@vicktor1111111: my above post reply is in response to your private email inquiry.
Nachricht 9 von 22
vicktor1111111
Thank you very much, here is my file.
Nachricht 10 von 22
Here you are.  Right click on the beam end grip and disallow join.  See screencast in a few minutes.
Nachricht 11 von 22
vicktor1111111
als Antwort auf: ToanDN
Thank you very much for your help. It has worked.
Nachricht 12 von 22
vicktor1111111
Thank you very much for your reply, it was almost the solution, only in my case I had to do this with grips on beams not on columns.
Nachricht 13 von 22
vicktor1111111
als Antwort auf: Anonymous
Thank you very much for your reply, but unfortunately it didn't help. As
Nachricht 14 von 22
@vicktor1111111: I cannot replicate in a new project. But I can replicate in your project. My solution is to constrain the Column Top Level to a level that is independent from the Beam Level, and then control Column height by changing the elevation of the Top Level. The Beam Level and the Column Top Level can contact each other without incident.
...BTW: did you notice your Warnings?
Nachricht 15 von 22
vicktor1111111
Thank you very much for your help. Although your suggestion doesn't work at once, if I use it and then follow the advice of
Nachricht 16 von 22
You can also use the Join Geometry tool to remove the visible edge between the column and the beam.
BTW, I said nothing of a Top Offset. I said use a TOP LEVEL for the columns that is not the same Level the beams are hosted to.
Nachricht 17 von 22
vicktor1111111
Yes, indeed, the result with join command is the same as after using your's and . Thank you very much, again.
Nachricht 18 von 22
vicktor1111111
The only question which torments me now concerning this problem is why, unlike in walls, in beams I have to disallow join instead of allowing it so that they got joined. Could you please explain it to me.
Nachricht 19 von 22
I was able to mitigate the automatic column-beam join behavior by using the method I described above. I did not need to toggle Disallow Join at every single beam corner.   Also, like I said, I did not have the same issue in a new project.  So, my guess is the you did something non-conventional in your Project.  However, I have seen your issue posted about before, so I guess it isn't that unusual.  Try posting the question on the Structural Forum. Most of us here are on the Architectural side.
Lastly, if you feel I was helpful, please feel free to give me a lil' green check mark.  You can give more than one.
Nachricht 20 von 22
vicktor1111111
Thank you very much. Sure. Do you mean press a best solution button? Only maybe I'll ask
