Columns not showing material
4 ANTWORTEN 4
Nachricht 1 von 5
sebas_alva_g
309 Aufrufe, 4 Antworten
Hi.
These concrete columns material should look like a diagonal hatch when cut, but it does not show it.
There are no visibility graphics overrides since there are also wood columns, with a different look.
The wood columns are looking good.
The concrete column family has the same material set. But is not showing the diagonal hatch.
Any suggestion on how to make the concrete columns look hatched please?
thanks
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: sebas_alva_g
Architectural or Structural Column?
What is the view's detail level (coarse, medium, or fine)?
Nachricht 3 von 5
Switch Join Order
Nachricht 4 von 5
syman2000
Look like your architectural column will autojoin with the wall and inherit the wall material. To avoid this, edit the family and check this off. Once you load into the project you can unjoin the column and the column will no longer inherit the wall materiel. The other option is switch the column to structural column category.
Nachricht 5 von 5
