Column with different finishes
Hello!
I am learning currently learning how to use Revit and I have a question regarding columns. I am modeling a high rise building and I need my columns to have different finishes according to floor height : the first 7 floors I need the column's finish to be stone and after that I need the finish to be paint.
I was wondering what is the best way to approach this.
Thank you in advance for your help!
L.Maas
As a starting point it is always good to check how it will made in the real world. Are those single columns or are they separate columns or is it a single core (structural) column with an (architectural) column 'wrapped' around.
If you approach it this way it gives you some clues how you possibly could solve it.
-Several different column types.
-Single structural column with architectural column around.
-Column with 'wall' wrapped around.
-Create your own column family
Louis
Please mention Revit version, especially when uploading Revit files.
Thank you! I will give it a try!
Seychellian
The problem with doing this overlapping method (besides from the scheduling aspect which will now account for double the number of columns and respective quantities) is that you get a display issue where there is a clash of hatches (see attachment).
Am I doing it wrong?
ennujozlagam
@Seychellian  hello,
in this issue you need to edit your column family > untick join geometry in the properties > save > reload again > change your existing column with modified one. thanks
