Column - Revolution error
2 ANTWORTEN 2
Nachricht 1 von 3
338 Aufrufe, 2 Antworten
I appreciate for looking into my comment. When i place the column family in 3D or floor plan the follow dialogue box a appearing. Could you please help me out to solve the problem. I have attached the .rfa file please take a look at it.
2 ANTWORTEN 2
Nachricht 2 von 3
RDAOU
als Antwort auf: Anonymous
@Anonymous
When placing a Revolved Column family (ie: a revolve in a 2 levels based family)... Set it the placement option to Height not Depth. Revolves tend to break in the Upside down world
Alternatively, if you do not want this to happen,
  1. instead of revolve use extrusions.
  2. instead of modeling the revolve straight in the column family, model it in a generic model and nest it into the column family
Nachricht 3 von 3
Another way is to fix the family:
Get rid of the horizontal reference planes you added to constrain the column steps.  Add the reference planes in Revolve editing environment instead (see image below).  Or dimension the Revolve Boundary Sketch lines directly.  Then you can place the column using either Height or Depth in project.
Attached is the revised family but it is Revit 2022.
